engine ID
Joe,
Look for numbers above the starter on a flat pad. Those are the numbers you need to check.
The right side of the block numbers don't mean much except the ones in the middle. But I can't make out the numbers entirely. Looks like 23E "70" ? Usually this means the day, month a=january, etc. and year.
From the right motor mount it doesn't appear to be a later block 88 and up. Those blocks require adapters to use that motor mount. ( Plate, angle iron, etc.)
Sometimes you can also tell somewhat the year by the large numbers on the left side ; 3.0/3.3...3.2, 3.5, etc.
Also look at the head on the left side- a circle with two numbers- 81, etc. for the year, shape of the intake ports, etc.
