DerSchwede
Hi folks,
does anyone know the specific centrifugal advcance curve (with the vacuum disconnected) of the D-jet dizzy ...001 ? I looked in the factory blue book I have, but it puzzles me even more. In the table it says 30 +/- 2 deg but in the chart I read 20 +/- 2 deg, all in at 3,500 rpm respectively. Another fact is that the chart says cam degrees, all other figures in that section says crank degrees. (Since I have the german edition from '76, maybe someone with another one can check for deviations)
Given that the book says that the engine advance should be 22 deg at 2,500 rpm I assume that the chart is misleading... or does it rally give 20 cam degrees = 40 crank degrees all in? I suppose no....
Please chime in if you know more about this.
Cheers
A
Cheers
A
