You will need a multimeter for measuring resistance etc.
The throttle switch only has 3 working positions, idle, part throttle and full throttle.
The throttle switch has 3 terminals the centre one [18] is common.
The upper one, terminal 2 is for the idle position.
The lower one, terminal 3 is for full throttle.
Throttle closed (at the idle position) 18 and 2 are connected
Throttle fully open 18 and 3 are connected.
Throttle part open none connected.
Adjust the switch as required, if that doesn't work then it may be broken or the mechanical setup of the throttle butterfly need setting properly.
HTH
Malc
