John Buchtenkirch
Surprise, surprise, I found a small rust hole in the top of the transmission tunnel :-| after the automatic was dropped !
Apparently there was no drain hose on the evaporator housing so some of the water ended up on top of the tunnel. Does anyone know if it’s possible to lift that evaporator housing up a ½” or so without pulling the dash & breaking AC connections so I can slip a piece of sheet metal under it for a heat shield ? Then I could weld in a proper patch.
If not I will hit it with Navel Jelly & paint and pop rivet in a temporary patch, a hole that small certainly isn’t a structural problem. Is there enough of a neck protruding from the bottom of the evaporator housing for me to slip on a drain house by pushing it up from the tunnel ? I’m waiting for parts being shipped from California so now is a good time to take care of this little problem. Other than that I have made some progress by installing the Bavaria pedals and steering column top half without the slush box indicator. Thank you :-D for everyone’s help. ~ John Buchtenkirch
