Dorchester
Markos, the center of the strike behind the knob measures 2 13/16" from the right edge of the door
Hope this helps
Hope this helps
Hope this helps
About 3 years ago when I tried to install a perfect 74 Knee Bar in an E9 I remember fighting for hours trying to get it to fit… I might have it backwards and I was trying to put an early one in my 74 but they were definitely different!
I finally compared the one that came out with the 1974 Knee Bar and realized that there was a minor difference of about 1/2 to 3/4 of an inch. Without them being side by side you would never notice the difference.
That difference made fitting the center console impossible without cutting and trimming the perfect knee bar which I refused to do…
As fas as when the round knob and circuit breakers were introduced I have always been of the opinion that they were only on a 74???
But obviously I could be wrong?
Scott you are right that square cut center panel is for a 1974...
Actually Chris, the decorative strip (aluminum) was a single piece on most coupes. i believe late '73 was when it changed. i have a picture of a '72 that doesn't have the hazard switch mounted on the grab rail.The decorative strip as BMW calls it has always been two pieces unless the 74 has a one piece strip due to the adjustable column. Could the opening for the column be wider on a 74? Likewise the center console should be the same as all got the same heater/vent control assembly. As Scott noted early grab rails didn't have the emergency flasher switch opening though.
Just in case no one else noticed.... this is how a very constructive and informative conversation is handled on the forum. I'm always impressed at how much knowledge is on this board.
Dan
interesting information -
so it looks like the hazard switch was moved some time in mid '72
still unsure of when the metal strip was changed to 2 pieces. my 2800cs is a very late '71 - built in feb. '71. interested to hear from some of the guys with '71 3.0cs and other early '72 3.0cs. i will take a pic of my car and post the 1 piece. my steering wheel is off, so it is easy to show.
my 3.0cs e9 is may 71
the metal is two pieces
the hazzard switch is in underdash panel
rgds
Hope this helps
