I removed the radio and the fuse is OK. But no power on the red wire that turns purple before the fuse. Where does this short loom connect too? Also noticed I have no power to the fan switch as well. Do these cable route under the steering wheel or to the engine bay? Also, any tipo on removing the bottom panel beneath the steering wheel. I see no screws or fasteners. Thnx muchHave we established that "stopped working" means no power?
I’m baffled at the immense depth of exact knowledge by HB Chris and others. I wish I had the fortitude, and desire, of study to immerse myself that deeply. I’m ever impressed with you all.Power comes lower spade terminal on back of fuse box, Number 10 on the far right side. You can see the fuses with hood release door opened, check there next. Nothing comes from the engine bay.
I checked power at fuse position no 10 when ignition is on and nothing. The purple direct to radio is ok there is continuity so cable isViolet from ignition switch provides power to fuse 10 and not directly to radio. Output of fuse 10 is used for the radio.
Yep. fuse goodDid you check for power on BOTH sides of fuse 10? It could be the fuse is blown or not making good contact.
That is bad news as it points to bad ignition switch...I checked power at fuse position no 10 when ignition is on and nothing. The purple direct to radio is ok there is continuity so cable is
fine. Radio works with 12V, so, it seems big Purple cable is not receiving energy. Where does the large purple cable come from? Ignition switch?
