Decoding my M30
'69 2800cs
Moorestown NJ
I'd like to know what motor I have in my car, and so far I'm coming up blank. It's certainly a replacement motor.
The block has the 3.5 on the side and the head is dated 1983. Current induction is two 32/36 webers.
The motor number is 40813799, which doesn't seem to tell me much, and I don't see any other numbers stamped in the same place. I tried putting the full number, then the final 7 digits into realoem but nothing came up.
The head has the numbers 277 358, which I've read is a casting number and doesn't tell much either.
Any ideas? I'd like to know what I have so I can plan out next steps.
Look on the pass. side of the block for the block date 1st and then run a compression test.
Post your results here.
An M90...I should be so lucky!
I found the rebuild receipt from 1998...piston part number is 11-25-1-286-438, which indicates an overbore 8 to 1 piston.
I'll still do the compression check when I get around to a valve adjustment.
