decoupe
(deceased)
I am well into the process of converting from a distributor, coil and carburetor to a fully digital EFI. Intake manifold/throttle body/fuel rail/MAP, Hall effect pickup (timing trigger) and high pressure fuel supply are all installed and I’m ready to install the ECU, coil packs and wire harness.
Almost none of the wiring associated with the old ignition system is used so I have opened the wiring harness back to the fuse block (that was slow and awkward) and eliminated all of it and any other circuits that were abandoned/replaced/bypassed over the years by myself and PO’s. This is what happens when you can’t drive the car for 6 months of the year because of winter. Idle hands are the devil’s playground.
I want to convert the diagnostic plug into a remote starter button and eliminate as many of the wires at the plug as possible and here I need advice. If the plug is arranged 1,2,3 as pins closest to firewall and 1,4,7 is the engine – the diagnostic plug is as below. For a remote start the switch should connect 1 and 7 (which is battery hot and starter). Correct? Everything else can be removed without creating any issues?
Firewall
1,2,3
Engine 4,5,6
7,8,9
Where
1. Battery hot
2. Ignition on
3. Negative (chassis ground)
4. Empty
5. Empty
6. Empty
7. Starter
8. Charge (alt light)
9. RPM/Dwell
Thanks,
Doug
Firewall
1,2,3
Engine 4,5,6
7,8,9
Where
1. Battery hot
2. Ignition on
4. Empty
5. Empty
6. Empty
7. Starter
9. RPM/Dwell
Thanks,
Doug
