Help
1970 Euro 2800CS, am in process of rebuilding drive shaft etc. Are replacing flex disc, center bearing, repacking CV joints, replacing motor mounts, and so forth.
Also replacing the differential rubber mount that attaches to the rear floor by 4 bolts and to the diff by one long bolt. Problem is the new one is about 1/2 thinner than the old. Part number by all the parts web sites and Mobile Tradition is 33171126951. Yet the new one is not the same as the old. I am 99% positive the mount removed is original. See photo link at end of post.
By installing the new mount will this not pull the rear of the diff closer to the frame, thus lowering the attachment point where diff attaches to the driveshaft? Would this also not change the running angle of the driveshaft? I have not yet fit the mount to see if there are any clearance issues.
What gives, why the difference? I could make a 1/2 spacer to retain the original geometry. Did BMW change this to change the geometry? Does it matter? What to do?
Help
jjs2800CS
Photos at the following link.
http://jjsandsms1.jalbum.net/BMW 2800CS Differential Mount/
Help
jjs2800CS
