Differential question
gazzol
Preston, England
Time once again to tap into the fountain of knowledge that is E9 coupe.com
Apologies if this is a repeated question
I would like to increase the ratio on my diff from the current 3.09? (e12 m535). I am well aware of the 3 common ratios fitted to the e9 that end at 3.64, what I would like to know is:- are the crownwheel and pinion sets from other vehicles fitted with the side loader diff interchangeable? For obvious reasons I would like to keep my lsd and get it rebuilt with a higher ratio. I've had a look on real oem and it would appear that the very early e12 520 was fitted with either a 4.1 ratio or a 3.9 and I have a source but I don't know if the crownwheels are the same bolt pattern and size.
Any ideas? Thanks
You need to open side wall of your diff & see on how many bolts crown gear is mounted on.
In general size of the gears/crown gear in side-loaders diffs are the same, just difference in how many bolts; if it 3.09 it's later side-loader, so it will probably have 10 bolts, but as it is LSD it also might be early 8 bolts LSD case, so you need confirm this.
Thanks for your advice
As long as you stick with e12’s or e12’s based e24 side loaders you should be good.
The e23/e24/e28 diffs were much different. As @Wladek pointed out, the side loader design matters. Since you are souring from “late model” side loaders you should be good.
