Dimensions for DIY Recaro Adapter Bracket
thehackmechanic
West Newton, MA
I have a pair of Recaros that I installed last month. I had bought and installed a set of home made adapter brackets from a poster on this forum, but they were too tall and the seat angle was wrong, so I went back to basics.
The original seats on my '73 3.0CSi have holes that are 13 3/8" apart front-to-back and 19 1/2" apart side-to-side. The holes on the bottom of the Recaros are 10 1/4" front-to-back (using the two holes that are the farthest apart) and 16" side-to-side.
If you work it out, that means that any adapter bracket has to move the holes 1.75" outward from the Recaros, and then have properly spaced holes downtrack to accept the sliders.
I took some 3/16" aluminum stock and cut two 3" by 15" pieces. I scribed lines down each piece that were 1.75" apart and equally set in from the sides. On one scribed line I punched two marks 13 3/8" apart, equally set in from the edges. On the other scribed line I punched two marks 10 1/4" apart, again, equally set in from the edges. I then drilled holes larger than they needed to be to afford some play. I painted the brackets black, bolted them to the bottom of the seat, then bolted the sliders to them. In the photos, you can see that the back of the bracket is longer than it needs to be because of course I measured wrong and was long by an inch (at least I wasn't short by an inch).
It works perfectly. As other folks have reported, the base of the Recaro is tilted unnaturally back, so you need to lift the back of the seat slightly to level it out. I used extra long metric bolts to thread into the base of the seat and shimmed it with 1/4" washers (the hole size, not the thickness) between the seat and the bracket. I'd put in a few washers, then drive the car around the block to test how the seat angle felt. The magic number was 12 washers, which raised the back of the base of the seat about 0.7".
At some point I'll take some black touch-up paint to the nuts, bolts and washers to make them blend into the black of the brackets.
This is a very easy thing to do. Grab those Recaros if you find them, and make your own brackets.
--Rob
I also just recently installed a pair of Recaro seats from the E24 M6/Euro 633csi and in my case the holes front to back were identical to my E9 coupe at 13-3/8, only issue was the width on my coupe was 19.5 and the Recaros were 18" so I fabricated a similar plate for one side only to gain the extra 1.5 inches in width. I put them on the side facing the transmission tunnel. I guess you can argue the seats are off center by 3/4" but you will never know by looking at them or driving the car. The install was very easy and worth the little bit of effort.
Huh... I thought every Recaro everywhere had the 16" spacing (rail-to-rail). Were you bolting to the bare base of the seat, or to a bracket that was already in place to adapt it to the E24?
You are right, it is a bracket specifically for the E24 which my rails bolted directly on to.
