What is the proper hook up of vacumn to a bosch dizzy with both advance and retard?
Let's also assume the following:
1. Was auto trans- now manual.
2. Had EGR ; but now does not.
3. Both vacuum lines at present are hooked up to manifold and not ported as would normally be the case.
4. Has dash pot for carb hooked to vacuum and continues through T to retard side of canister.
My thought- pull all that crap, hook up the advance only to ported ( carb) retime for near max advance? ( 36-38 degrees)
My theory is that the engine is not getting the proper advance or under some scenario is getting too much advance and possibly contributing to a heat issue. Flushed the radiator, changed the stat. Better, but not where it should be.
Thoughts?
Thoughts?
