nealf
Hello all:
I am not sure any of you remember, but several months ago I swapped out my aftermarket distributor (dual point, Roto Faze, Ford Motorsport cap) to a stock Bosch unit. The car, a '70 2800CS ran like a raped ape but sucked down large amounts of fuel. I also discovered a need to rebuild one carb which I did. The car has not run better, in fact it runs worse that before. I wondered if there would be harm in putting it back on assuming it will run well once again.
I just cannot understand why it would run better with an aftermarket dizzy, rather than the one that was designed for it. Maybe whomever set it up knew something? I bought the car 2.5 years ago with no history other than that it was from the West Coast.
Any thought appreciated.
