nashvillecat
- Messages
- 115
- Reaction score
- 7
Can a so-called upgraded smaller starter (with only three electrical terminals) be adapted to work with the Djet models?
I have a newer style starter (smaller w/permanent magnets) that many of the early 70's and 80's BMW’s use as a common replacement/upgrade for their cars. It was a spare for a non-e9. Sticker with model number is missing. Unlike the OEM starter solenoid, the solenoid on the “newer” starter has only three electrical connections. The OEM starters have four prongs. I suspect some of the newer smaller starters actually have a solenoid with 4 connections, but this newer starter has only three.
From what I gather, only three terminals are necessary for the starter to function with carburetor models: 1. the negative ground; 2. no 50; and 3. No. 30 (from battery). I would expect the cs models might be able to do without the (16) terminal if they used some sort of pointless ignition system. But - the djet equipped models evidently need that fourth post (16) as part of a timed relay/bypass to the coil and the fuel pump during startup. Or do they?
Anyone use the three-terminal-solenoid starter on a djet? What was connected, bypassed, rerouted, or rerigged? If this is more trouble than its worth, I will look for another starter that will work.
FWIW, the realoem diagram is somewhat misleading in that it looks like a three-pronged affair. PN 12411272150. The usual replacement/upgraded starter looks to be an SR95X. As I said, the sticker on the newer 3-pronger is missing, so I can only guess at what it specifically fits (I have an inkling it is an SR41X for a 635csi but I am far from certain).
Thanks.
Thanks.
