brian c
As a new owner of a '74, I've been going through the mechanicals of the car and tossing stuff that wasn't connected or was part of the EGR system. Car has stock Zeniths. EGR was rendered inoperable but all the plumbing was still there. I took off the EGR filter and ss manifold tubes, removed the vacum switches on the firewall that went to the EGR. Plugged all fittings. The only remaining component which still looks hooked up is the dashpot with its vacuum switch. Can I pitch this? It looks like it is also wired to a relay or speed sensor? box on the front of the engine compartment under the fresh air intake. There are two boxes there which I think I can pitch. Correct? Sorry no pictures, I will try to add if there is any confusion. Thanks for any help. Brian
