DOB Rusty Pics
Malc
The Garvock, Scotland
For the Technical section, maybe
Scraping the underseal of the car, lower shows rust had got underneath . Top, underseal pulled off by hand...
If you are looking at a car check the underseal to see if it is loose as it can hide this kind of trouble.
Worst places "so far" seem to be around the tags that hold the fuel and brake pipes, plus component mounting brackets such as the rear brake flex hose mounts.
Basically anything that has been welded to the floor pan or has sharp edges.
Malc
Rear Suspension mount, Shock absorber tower is surface rust, but bump stop mount / spring locator needs work. Note rot in arch behind
Philip Slate
I haven't decided if you're a Saint or insane.
I suspect the latter!
Although her in doors is pleased I am in the shed and not the pub
and I am always up for a challenge
Yours, soon to be committed
Malc
