does anyone have a motronic 1.3(179ecu) ecu pinout diagram?
daicos35
Sydney, Australia
Thanks to another kind member, I am chasing up a "plug and play", fully programmable ecu, that uses a in built MAP sensor (removing the AFM).
It is built specifically for the 8-91 e30 325i m20 engine, which has the same 55 pin ecu, and is listed as a motronic 1.3.
If the pin maps match, it will very cost effective!
You may find something here:
http://www.vectorbd.com/peugeot/bosch.html
Unfortunately, the links specifically mentioning pinouts and Motronic 1.3 are dead. I can also check in my E28 manual and see if it has anything, though I'm pretty sure they all ran 1.1.
Once you get the info you need, even if the pins don't match up it should be a pretty simple process to repin the connector. I haven't played around with the Motronic connectors specifically, but most of the time you can use a tool to pop the wires out and put them wherever you need them. What kind of ECU is it? I know several people who are considering building a Megasquirt inside a Motronic box and wiring it up using the stock harness and connectors.
http://www.wolfems.com.au
Here is the link to the Australian site.
They have USA distributors listed.
The ecu replaces the motronic box all together and includes an inbuilt MAP sensor, so you just plug it in, and run a vacuum hose to the box.
