pamp
As me bride and myself were under way to sunday brunch, the coupe died.
(this was last winter) It was a fine sunny day. To make a long story shorter,
it then snowed heavy. Friends took us home, provided refuge for "Sienna"
I returned with tools and a tarp. She no wanna start no way as I had no fuel pump actuation. Had to get a tow back to my shop, after the snow melted a bit, to do proper diagnostics (that means that I failed in the field) With superman x-ray vision, I found that the fuel pump relay had been jumpered,
(previous whoever)and the jumper had come loose. Naturally just loose enough to make the deal "intermittant" This relay is hard to find, in the engine bay, as it is mounted to the side of the brake master, low, lot's 'o stuff in the way. Well needless to say that the relay was toast (hence the jumper) Bosch #0 332 003 014 This part is "unobtainium" where I live.
Anyway, here was the fix...#0 332 003 021 a VW part readily available. But... you must gently rotate the center spade 90 degress (10/51) Voila'
021 becomes 014.
I would love to hear more stories. As the parts get fewer and far between ...
021 becomes 014.
