Door Card Renewal
bavbob
Boston, Ma
In trying to keep everything original in my E9 restoration, I refurbished the door cards as follows:
This is what I started with , kinda mangled from warped press board.
I then washed them with a 50-50 simple green and water mixture. The press board needs to get soaked through and through.
Placed them vinyl side down on a flat surface and used boards and free weights to flatten the press board straight. Drying time was about 12 hours. I focused the weights on the specific sites that needed to be flattened. I used wood blocks under the boards for areas that were small to focus the weight on any small, warped areas...
Once dry and flat, I had this to work with..
I used JB Weld ( the real stuff rather than the quick dry) to fix any cracks in the press board. If they were big, I had a sheet of 20G steel that was 1/32 thick and cut small pieces to bridge the cracks and used JB weld to hold these in place. I then replaced any broken door panel clips.
Then applied Minwax or Varnathan wood hardened to the press board. It soaked the stuff up. This is almost a thin epoxy-like liquid that bonds the fibers together and really stiffens the board to keep it straight and stop if from warping.
I followed with another cleaning of the vinyl side and then SEM vinyl paint that was matched to the original by a local shop for me. I really think the wood hardener is the key here. Quite content with the results.
there are many materials you can use for the door panels. plywood (very thin), waterproof panelboard (from a company like Keyston Brothers or a local auto upholstery shop) ... or reuse the boards in your car as BavBob did. i think he is correct, the hardener is what keeps the panels flat which is what makes them look new (combined with refinishing the visible surface)
Bob - are you using the new clips BMW sells to hold these in place? I seem to recall they do not work nearly as well as the original design.
Yes and no.
I used all the old clips that were intact. I used new ones otherwise but totally noticed they are not as long and lack a "shelf" to snap into place. On the other hand, the little plastic female ends in the door do not allow the "shelf" to bite into anything anyway. I have some knock-offs from China that are the same length as the originals but have a second collar just below the first one ( the new BMW ones have only one collar). I was worried that the panel would not sit as flush with the knock-offs. I will play it by ear and see what happens when I go to put the panels back...which is a while away. I may swap all the new green BMW ones with the knock offs or look for an alternative if the panel won't lock into place.
Yes and no.
I purchased a set of thin plywood door card backs and transferred the vinyl onto them. When installing them, I used the BMW green clips, but the stiffness of the plywood made it very difficult to get some of them to bite and stay in place. I broke several of them in the process, and a handful of them have let loose on the front of my passenger side door.
I would like to be able to buy a set of replacements with the same design and material as the original, but I was unable to find that option.
Probably too late but if you want, I will send you some of the knock offs I have. With the extra collar, they stick out a few mm more than original and may solve the problem (though may have door card away from the door by a few mm also).
Bob -- thanks for the kind offer. When I pull the door panels again, I am going to change to something else. I found a Porsche part that looks like our original; I am going to buy a couple of those and compare them. I've also got an e39 part that is longer; perhaps more taper will allow them to go in without breaking.
FYI - the plastic female ends are a water barrier. The replacement clips have that second "shelf" to act as a water barrier, and are designed to be installed without the female end.
That makes sense....but my 73 had the longer clips and the female ends. I think BMW performed an aberration on random cars back then just to make life more interesting for later owners.
