pmansson
Putting the parts back after a complete respray is going OK. Takes time to get it all perfect.
On a couple of cars I have the issue of the door window (at the top/closed position) hitting the front end of the J shaped chrome liner (with riveted squegee and NLA felt part) of the rear quarterlight.
I would like to shave off a few mm at that low part of the door window where it hits the chrome when closing the door (with a fully raised window). I don´t know if the glass likes the rotating head of a Dremel cutting into it....).
Next option is to shave off a bit of the black positioning piece inside the J shaped chrome liner, so that it will allow the chrome part to be knocked further back.....(yes, I could drill a second hole in the body, further back, to allow a different mounting position of the black part).
Any other suggestions.....??
The door glass has a new U-felt part in the vent window rail. I doubt that it pushes the glass rearward that much. Other than this, I can´t see how the door glass can be pushed forward to avoid the knock on the quarter light chrome.
The easy way is to close the door with the door glass down a bit, but this only works when I´m inside the car.....When driving off, I can raise the glass fully (and not forget to open it slightly before opening the door.......
