Door Jamb Seals
kys911t
So Cal
I think there is suppose to be two rubber seals, one on each side of the Aluminum piece that fits in the Door Jamb, lock side. I think one of them is part number 51716754295. Does anyone know the part number of the other? Or if the other number is correct too. Thanks
The seal that goes entirely around the door opening is one, the second one glues to the door itself on rear edge, third glues to underside of door. Numbers 1, 8 and 13 in realoem diagram. #13 is ridiculously expensive!
Sorry I should have attached this to begin with. This is the Aluminum Piece that fits inside the lock side jamb. The Latch is bolted through this piece and there are two stainless recessed oval screws one at the top and one at the bottom. There seems to be two different pieces of rubber that goes along each long edge. I have the three of the four for both sides but they need to be replaced.
There are two seals:
A thin strip which fits on the aluminum between the quarter panel.
The long door weatherstrip the which covers that inside edge.
All three are available. Your part number designation below is the piece that fits on the outboard edge of the aluminium shut panel. You need two, one for each side (not handed). $11-12 ea.
The large door weatherstrip ( HB Chris describes it best- it goes all round the door) : You need the left and right. But it certainly pays to shop around as they are expensive even though they've come down in price. 51716754282, left. 51716754283, right. There have been several posts discussing vendors and prices so a simple search will help.
DeQuincey had a pictorial of replacing the seal your discussing. I believe it was with replacing rocker trim. Worth a shot to look at how he did the work. +1 for DeQ.
Of course there are other seals as Chris says, but you asked about the al. shut trim on the door opening.
Yikes- the curved seal is $90. I agree with Chris.
Tip- if your seals just need recoloring- vinyl dye with proper prep.
