Door key do not work!!!
OLD_DTM
Westchester, NY
Hope someone can help me with this, I have a matching door lock and Ignition key, Key works fine on Ignition but does not work on either door...
What can I do to resolve?
thanks
You can still find locksmiths that can rekey your Door locks to the ignition key especially since you already have door locks removed.
That is a valet key - standard key has 7 dimples.
I just went through this as my only key was 6 dimples. Email Stuart at keys4classics. [email protected]. He will ask for the key code which is on your lock and make you copies of the correct 7 dimple key. I would also spray some silicone in the other locks when you receive the new key as they likely will be sticky from lack of use. Mine were but now open smoothly.
THANK YOU! guys. I left both locks overnight on a container fill with WD40. This morning I pull them out and they work fine!!!
