Door quarter light outer seal
frogisland
Cheshire, UK
Is there a part number for the seal between the top outer chrome door capping and quarter window?
Its quite a small 'T' seal and not able to find alternative that small.
Photo attached
51211813195, sold by the meter, #12 in diagram on RealOEM, is window sill but the one you want is long ago NLA.
If I am correct the part number that is available mentioned above will work if you put it along the top of the chrome then when it gets to the little end piece you need to cut with a razor. The problem is that when you put the chrome back on the little rubber piece wants to pop up, so you need some glue to hold it down and that carries with it other little difficulties but to the best of my knowledge that is the only way to get it to look correct. I only had to re do it 4 or 5 times :)
Oh! you are talking about the whitish plug T the top. I missed the 'TOP" part
This? >>
I need on as well.
Thought you were talking about this lower seal wrap technique.image.jpg I
