pmansson
Thought I´d share the following with you (and many of you might already know it).
It is a well known fact that the early window mechanisms with the sardine can motors work a lot faster than the later ones. I think it changed in 1974 or late 73 (but don´t understand why....)
Today I tried to mount the early package in the later door (doors must have been changed during a restoration about 20 years ago. The car was made in Sept 72).
The early package fits and the holes match, although it uses different holes than the later package.
BUT, it doesn´t work well at all. Something prevents the easy movement and causes the fuses under the dash to pop. There is also a part grinding noise. It doesn´t help to release the upper screws. What a pity esp as the holes match.
So I cleaned the existing/later package and put it back again. Works a bit faster but still nowhere near as fast as the cars with the early package.
