NiekN
Hi all,
I'm currently designing the new wiring system for my '74 CS rally car and I'm in need of some help. I'm trying to activate the high/low beam using two seperate switches, in that I want to keep using the stalk on the steering column but also have the floor switch installed. So far I've got it working only in a way that the low beam remains on whenever the high beam is active, but in theory the low beam should be off at that point. Does anyone have any idea as to how I should wire this system, if at all possible? I'm using seperate relays for both high & low. Thank you in advance!
Kind regards,
Niek
PS. I'm running the full restoration on my website and YouTube channel; If there's enough interest I'll post it on here as well. (for the purists among us, this is not a factory standard car when I'm finished).
Kind regards,
Niek
