I recently acquired a coupe that had been heavily undercoated by the original owner. It's been kept dry most of its life thus far and is remarkably rust-free. While inspecting the inner rear wheel arch and rocker area after removing the rear window assembly I noticed the drain hole is covered by the undercoating material. Do you recommend poking through these holes to allow drainage? I am not planning on driving in the rain but you never know. If so, does anyone know the location and number of all the drain holes in the coupe (panels, doors, floors, etc - no sunroof on mine)? Any drain holes I should create? I then plan to blast waxoil or the like up into as many cavities as possible. Thanks.
