corsachili
I'm curious if anyone has experience or knowledge regarding installation of the aluminum drip rail trim. I just purchased two new pieces to install and it appears that they merely get "twisted" on, reversing what you'd do to remove them. I've installed and removed these things at least 10 times over the years, but I've never installed brand new parts and assumed that they get damaged or tweaked after they're removed the first time.
It appears that the best practice is to start at the back (near the c-pillar) and work your way forward. It also appears that merely snapping them on is all that needs to happen, in other words, no crimping (which would obviously put a mark or blemish in their finish). Finally, it appears that the front end (which terminates at the front fender) is supplied an inch or so longer than necessary, and gets trimmed to fit.
Any advice, cautionary tales, encouragement (discouragement?), or pep talks before I install these things?
-tj in los gatos
-tj in los gatos
