I'm trying to change my guido and center bearing support. I had a heck of a time removing the bolts from the dif and trans but got them loose. I have also removed the muffler and the pipes to the Header Pipes. Now the manual says I should be able to bend the shaft and get it out, but it seems like the pipes directly attached to the exhaust manifold are in the way of the old guido. Do I need to remove the pipes from the exhaust manifold or should I keep trying to maneuver it out? Those pipes attached to the exhaust manifold look like a real pain to get to and remove. Would appreciate any feed back or suggestions. Thanks
