Driver Side Front Window
Pull the access cap on the door and see if the gear moves when you move the switch (ignition on). If it moves it's just stuck, if not then get out your voltmeter and check for power at the switch then if none, check the fuses, then the motor after pulling the panel if all else checks out.
