couttsdesign
I'm in the process of a 5 speed transmission swap (Getrag 265) and the problem I am having is that my driveshaft is too short by about 1/2 inch. I think the shop where I had my d-shaft shortened may have done it incorrectly because now my driveshaft seems to be one continuous unit, in other words, the front section does not longitudinally slide in and out of the rear. Is the front section of the driveshaft supposed to be able to slide in and out of the rear section of the driveshaft? Is the driveshaft length supposed to be a constant length or is it designed to have slight longitudinal movement at the center bearing??
