Drive mine in the rain if I have to (matter of having to here in NZ, rains quite a bit at times), also wash it with water and use a pressure washer to do so, but with a soft spray nossle from a goodly distance from the car.
As for rust protection, when i rebuilt it I spent a lot of time squirting Rust protection spray everywhere I could, sills, strut tops, doors, pillars etc etc
The most important part as far as I'm concerned is the strut tops, I have completely closed of the openings in the inner guards at the back of the front wheels and the open part of the guard above the wheels, for each side I made 3 separate 3 mm thick plastic filler pieces, I put rubber lip mouldings around the edges of these to help with sealing to the body work, any small gaps I had after this i filled with a flexible body sealer, and lastly a nice layer of under sealer over the top of everything.
I left a couple of small drain holes in the lower points to allow any stray water that does get in to get out, these I shaped in such a way that water and dirt can not be driven up into them, these filler panels are screwed in place, so after a year or so I can remove them, re treat with cavity wax etc, and refit them.
Quite a bit of extra work, but I didn't want to own a garage queen that only came out a few weeks a year when it's fine. Now that it's finished I'm going drive it rain or shine and enjoy it.
