blumax
(deceased)
Updated again--E-9, some E-3 and 2002 parts
Many new to parts listing--all parts in Costa Mesa, CA
>Distributor part #0231142002-fits E-9 & E-3 rebuilt by Bosch technician-never used--$250
>2937 New radiator cap and good used oil cap--both caps--$15
>2938 Not sure where these nuts and hardware fit in an E-9--do you? make an offer--??
>2939 Cigarette lighters and control knobs all in VG condition-lghters $15-knobs $10 each
>2940 Four prong window switches-cosmetically challenged but serviceable-all for--$35
>2941 One blue & one black upper armrest connectors-cover for window motor--$5 each
>2942 Fasterners for securing front & rear carpets to floor of E-9-RARE parts-all for-$35
>2943 Misc. for mounting badges, door hnd'l bumpers, securing door & lock rods, etc.--$25
>2944 Assorted roundels for hubcaps, etc.--$20
>2946 E-3 lock buttons & headlight adjusters--$10
>2947 Variety of underhood stickers for E-3 or E-9--all for $10
>2948 Various underhood stickers for 2002's--all for $10
>2949 Point file for anyone still using points in an early BMW--$5
>2950 New clutch pedal pad, used E-9 vent window wheel, 2 2002 vent wheel inserts--$20
>2951 Suspension & sway bar bushings for 2002--$20
>2952 Trunk hinge cap--has blue paint overspray--$5
>2953 Stainless carriage bolts-good to fill ends of license plate bracket--$5
>2954 Door crank handle insert--has sign of wear-good condition otherwise--$5
>2955 Miscellaneous new pieces of hardware--$5
>2957 2002 heater and ventilation slide arm control end pieces--$5
>2958 Late toolbox fastener, door hnd'l bumpers & special nuts for 2002 trim--all for $10
>2959 Two pairs of E-9 hood latches will fit E-3-used but good condition--$20/pair
>2961 Good pair used manual window crank handles-fit E-9, E-3 or 2002--$15 each
>2962 New center section of passenger door seal at "A" pillar-it's often missing--$20
>2962a Anodized trim strips--upper door window glass-2 in fair shape--both for $20
>2963 Original used relay that goes inside drop down access door--$10
>2964 Battery hold-down clamp-as new condition--$10
>2965 Steering wheel nut--in case you don't have one--$5
>2966 Original roundel for the nose of your e-9-needs an artist to refinish--$5
>2967 Box of 4 NGK BP6ES sparkplus-enough for your 2002 or 2/3 of e-9--$5
>2670 Shifter boot in VG condition for your 2002--$15
>2671 Red rear reflectors for your e-9, e-3 or 2002-in VG condition-pair for--$25
>2672 Brake fluid reservoier with cap and float--tiny hole @ top was repaired--$25
>2673 Power window acces plugs-clear-6 available--use vinyl paint to match your interior--all for $20
>2674 Faux pieces-good for underhood corners @ base of windshield-each pair--$10
>2675 Assorted Heyco chrome-vanadium tools+gray screwdriver & H-1 bulb-all for $120
>2676 New seal-between S/S lower trim-at rear of body & at front fender-one side--$20
>2677 New replacement mirror glass, for trapazoid+mirror base piece & base seal--$30
>2678 For an E-9 purist who wants smog crap-eerrr equipment-for that original look--$35
>2679 Assorted wiper arms, blade carriers and S/S inserts-some E-9 & 2002--all for $40
>2680 Pair of headlight access covers-E-9-VG light rust-need to clean, prime & paint--$30
>2682 Psg'r side turn signal-excl't lens & chrome base-tiny crack in base invisible when installed-no bulb socket--$35
>2683 VG trunk lock for E-3 or E-9--$25
2484 Black barely used passenger armrest-near new condition—$40
2486 Mitchell 1987 collision estimating guide older imports—includes BMW parts--$10
2498 Driver side “B” pillar seal holder & trim strip-fits R/L rear inside quarter panel--$20
2511 Complete E-3 instrument pod-with all instruments in VG condition--$50
2619 Excl't 2800CS air box-wrinkle black finish with silver air horn-came from BLUMAX--$50
2620 Pair of original horns from BLUMAX-clean & fine working condition--$35
2620A Three original 75 mm clips for original A/C set-up--$10
2629 TS/WSW switch-operating condition unknown-believe it to be repairable--$20
2633A Window control switches for E-24--$15 each
2636 Center console metal grill for E-3 in VG condition--$30
2636A Selection of VG E-9 or E-3 "pimple free" interior door handles--$15/pair
2644 Used fuse block no cover--believe to be good--$5
2645 Used set of four E-3 exterior door handles-in very good conditions--$25
MORE COMING LATER--DOWNSIZING 30+ YEAR PARTS COLLECTION
Please communicate with me by e-mail: [email protected]
