Got these a while age intending to upgrade the very pedestrian front windows.
As the car has now gone to a new home, these are gathering dust (metaphorically speaking; they are well stored)
So anyone want them $65.00 each plus shipping.View attachment 87991
Yes is a good one.
Here is the write up
Restoration of a 1972 BMW 3.0CS - Window Motor Conversion - Part 1
Converting front E9 window 3 wire motors to later model E28 2 wire type Overview This procedure describes the conversion of the left front E-9 electic window motor from a 3 wire 2 piece motor to a later model 1 piece 2 wire motor from a BMW 5 series sedan. The is based on a 72 3.0cs with electricsites.google.comRestoration of a 1972 BMW 3.0CS - Window Motor Conversion - Part 2
Modifying the Wiring Modifying the wiring to allow the existing switch to be used with the new 2 wire motor is actually much easier than you might expect. Essentially you need to provide a ground to the free connector on the drivers window switch, and you connect the blue and the green wires fromsites.google.com
Yep they are. Will pm youI'll take them if still available
Yours is a later car so does not have the sardine can motors so the upgrade is easier with no cutting.
