E3 2500 Vacuum line diagram
ashnz
New Member
Auckland, New Zealand
Hey guys, new here - I have just bought a 72 2500 here in New Zealand that has been sitting unused for 25 years.I will post some photos in the project thread, she needs a bit of work!
Previous owner has just cut all the vacuum lines off for some reason and I am having a bit of trouble piecing it back together.
Does anyone have a diagram or photos showing where all the vacuum lines are meant to go, namely the dizzy and carb lines.
Any help would be awesome
Ash
The vacuum advance line comes from the front cone shaped side of the dizzy advance dashpot and goes to the front carb on the valve cover side above the butterfly. You can also link it to the rear carb but it is not necessary, just block off the port on the rear carb. Retard comes from flat rear side and goes to intake manifold below the butterfly.
Thanks alot mate, I thought that might be the case. Are there any other lines that go anywhere else? I found a big tee'd off section that went into the cabin and into the Drivers side foot well (RHD). I cant see what that is for, although I did see an air type switch in the drivers footwell that is labelled something like "automatic roof" - but the car doesnt have a auto roof.
