Dave H
New Member
I'm cleaning out garage and have some E3, E9 engine parts that need to find a new home. Below is a list of some of the ones I have. I used realoem.com to research part numbers, I think they are pretty accurate. Please see pictures attached. I'm not sure of value, so any help with that would be appreciated.
11 13 1 254 979 Camshaft 272 degree ("3" on end of shaft)
11 21 1 716 122 Crankshaft
11 62 1 250 601 Exhaust manifold
11 72 1 257 132 Air pump
11 72 1 260 136 Air pump bracket
11 74 1 259 958 Vacuum control valve
11 81 1 105 693 Left supporting bracket for motor mount
13 21 1 252 253 Vacuum box
13 71 1 257 721 Air filter housing (13 71 1 263 002)
13 21 1 252 539 Bracket, vacuum box holder
13 21 1 260 377 Throttle lever assembly
23 23 1 202 739 Transmission synchros (NOS)
32 41 1 250 620 Power steering pump support bracket
51 14 5 480 181 BMW hood emblem (82mm)
71 11 1 116 843 Wheel pin (71 11 1 093 774, 71 11 1 102 733, 71 11 9 090 104) (NOS)
71 11 1 103 085 Pin (NOS)
71 11 1 179 745 Spark plug wrench (71 11 1 126 473, 71 11 1 103 083) (NOS)
71 11 1 180 677 Box spanner 10 x 11mm (71 11 1 181 418, 71 11 1 103 084) (NOS)
