Buffarea
In the past two weeks I have been trying to drive my E3 everyday. Last week I set valves,timing,cleaned points and plugs and isolated/repaired and spark jump from a faulty plug boot. I also removed and tested the thermostat, but did not replace the coolant. The coolant and oil in the car are who knows how old but levels and condition "looked" ok.
This week the idle has been slowly going up even after fully warmed up and "blipping" the throttle to bring it down is becoming less effective. Yesterday while setting at a light I could hear a gurgling/purging liquid type noise but no loos of fluid. I noticed that there is no heat and thought that perhaps the heat/vlave control was inop., but on the way home the car began to misfire. I found #4 and #5 plugs very sooty and replaced them, at which time I checked the coolant and found it to be 1.5gals low!
After topping it up I let it run until hot, and think now the idle issue is due to a vacuum leak on the rear carb., which I presume is causing the sooty plugs, but where did the coolant go?
