E9/2000CS Parts Compatibility
CarSnob
New York
Hi all. I'm trying to locate front and rear window trim for my 2000CS. I know that the E9's and the 2000CS are visually similar from the A-pillar back, but are the parts the same? I'm having quite a bit of trouble finding the trim specifically for the 2000CS, but if the E9 parts are the same then that'll solve quite a few problems. Also, if anyone knows of a website that would allow me to see which parts are cross compatible that'd be very helpful as well. Thanks in advance.
go to realoem.com ... research the part number on the 2000cs - then open another copy of realoem and enter the part number in the parts number search and it will tell you which other cars use that part number
Salut vitre de portes et custodes sont identique , sauf les fermeture de porte et les portes qui sont légèrement différentes
Hi glass doors and rear quarter panels are identical, except the door closing and doors that are slightly different
