E9 clutch
Mechanical clutch is long NLA, the two viscous styles are available, the newest 'spin on' style uses a newer style pump.
Just purchased coupe month ago , has five blade red fan and I assume this is the mechanical clutch. It is very weak . I assumed from my search that is what I would find, shows no where in parts . What all do I need to purchase to change it? Thanks
Your pump will accept the first viscous clutch with four bolts to hold a cone piece to your pump which you will need. Or, new style pump with single large nut, the spin on model.
