e9 diffs.
Simufly
Cheshire UK.
anybody know how to decode the markings on e3/e9 diffs. I have a couple and would like to know the ratios.
There should be two numbers stamped on the diff case, indicating the number of teeth on the pinion and crown gear. Their quotient is the diff ratio. 3.64 is common but there are a couple others.
Did you consider the Search function? That's what it's there for. This topic has come up several times over the years.
