2tonic6
New Member
I am looking ahead to install a 3.5 l engine from 1985 gray mkt 635 with 5 speed trans. into my 1971 2800 cs 4 speed config. What are the major considerations or problems I will encounter? Many thanks!
[email protected] said:I am looking ahead to install a 3.5 l engine from 1985 gray mkt 635 with 5 speed trans. into my 1971 2800 cs 4 speed config. What are the major considerations or problems I will encounter? Many thanks!
[email protected] said:Thanks, I will have an entire car to go through for all the parts needed from the '85 Gray mkt 635. I would like to go with motronic and the fuel infection.
I'm pretty sure this is only an issue with the 89 and laters 3.5s.dp said:As I recall, engine mount location is different on the drivers side of the block, requires a fabbed mount to reach forward from the (farther) back location on the block to the mount location on your E9 crossmember.
