The text is as follows....
Thank you for the heads up. it must be an issue with Ebay international. Unless you are talking about grammer or spelling. The text is as follows:
Amazing set of Vintage BMW parts! E9
INCLUDES ALL: Complete instrument cluster!! Gauges, wiring harness, wood surround. Speedometer, Tachometer, fuel gauge, clock. VDO Kienzle. These gauges are very rare and getting one or parts to fix one will only become more difficult. Their value will only go up! The wood surround is solid but the veneer needs to be redone. Black metal surrounds look very good.
Interior parts: Headlight switch (part T3501513), AC knobs, side and rear ashtray, illuminated column mounted gear indicator, rare metal trim pieces for steering wheel, seat belt bolt covers "KLIPPAN", seat belt holder clips, ignition key surround(black plastic says "FHART START HALT O") , window switch (part # 0343302033)
Engine bay: Hella light assembly for under bonnet, oil dipstick, cast aluminum valve cover [(restored and carefully polished, looks amazing. could be for display) 1250105 on inside/ zundfolge 153624 on outside] , the black plastic tube that mounts to top of valve cover, 1 radiator mounting rubber brace, and...
One air cleaner /air intake cover. This looks like it has not been touched in 44 years. Patina...this has been hanging up on display. See picture. People love it. Solid. could be restored or displayed.
Air intake, air filter holder---this is one item that is not straight or in good condition, but there are parts that can be used or it could be straightened.
Original Hella horn. Tief 12V TE6.
Right and left complete headlight assemblies. They are solid. Never damaged. These are about the only thing you can still actually buy from BMW and they are $360 per side! That does not include the chrome surrounds. Accidents happen and these parts are not getting any easier to find. The Hella sb106 chrome surrounds are in beautiful condition. Chrome is as new. The bulbs are all GE sealed beam, no chips or cracks. They look new.
Chrome surround for dome light included too.
All from car that was bought in Oklahoma stayed in Texas. Car was stored for last 39 years.
This is your chance to have the item you need and... you will have some spares on hand for when you need them! So EASY! Get this absolutely original set before someone else snaps it up!!!
All original equipment from 1970 BMW 2800CS see pictures.
Buy it now before it sells to someone else!
