Hello and thank you , but my car is not a automatic it is original 4 speedGo thre wires direkt under the steering column through the fire wall?
Converted ex automatic car?
As I remember, that connector is for the shift light from automatic.
But im not 100% sure.
If so, no function, blind wires.
Breiti
Hello and thank you, this was a big help it is for signal light and or for wiper switch that is great I will try it todayAlbert, I have a couple of shots below that may be of help. I took these while taking out the steering column.
I think that the 6 space plug runs up into the steering column.
View attachment 176376View attachment 176377
and what kined of relay it is or what is that relay is for I don't think I have that I will try to buy one but what is the relay is for.Albert, I have a couple of shots below that may be of help. I took these while taking out the steering column.
I am not sure, but I think turn signal...and what kined of relay it is or what is that relay is for I don't think I have that I will try to buy one but what is the relay is for.
Thanks Steve. It was not working when I pulled the assembly, but I will make sure not to connect it when I re-fit.The small can relay in the steering column is the (annoying) ignition key warning buzzer
Hello, if that relay is for bosser we can forget about it I have nothing on it and was wondering what is it forThe small can relay in the steering column is the (annoying) ignition key warning buzzer
if it is I dont have it I have to look for it to buy, but I was thinking turn signal is with the emergency signal relay that is little bigger than that if I am not mistaking, however I will start looking to buy one, I have many rare extra parts but I still need many to complete my carAlbert, I believe the relay that you asked about is a turn signal relay.
Yes the "L" connector goes to the turn signal relay, the metal can in the steering column is the buzzer.Albert, I believe the relay that you asked about is a turn signal relay.
