my drivers window sometimes gets stuck at the bottom. Easy enough to free it off once I've taken the door panel off , but keen to fix the cause rather than continue to treat the symptom.
With the panel off, and repeatedly running the window fully down I really can't see what is sticking. When it's stuck the sardine can makes a good effort to move things, but only goes about 1/4 turn of the motor spindle. If I manually turn the spindle even slightly it releases the jam and the motor is fine
I think I have two options, find what is causing it to jam, or adjust the fully open window stop position.
Can't see either the cause of the jam or the window stop at the mo.....
The window is well aligned, hence I'm not going for a suck it an' see approach; keen not to make things worse (call this wisdom gained through experience
