Rek
When I use the right indicator (turn signal), the front works but the rear doesn't but somethines there is a slight glow to the bulb. The left side all works.
In the right side when the front is working it stops working when the brake is pressed. Same with the hazard flashers which work apart from the rear right, but they all stop when the brake is pressed.
Things checked so far:
Rear light cluster seems to be fine.
Hazard flasher seems fine (but might not be)
Flasher unit seem to be working fine
No sign of a short, but it could be hidden
Brake light switch seems fine
Does anyone have any ideas? I think I need Hercule Poirot or someone similar.
