Electrical Quiz
decoupe
(deceased)
Alberta, Canada
The EFI conversion is complete and still doing base programming before the taking it in for dyno tuning June 11th. Good news.
The bad is that in the process I have lost turn signals, wipers, brake lihgts and anything else on fuse 6 (which is not blown). What one wire and connection would cut power to all of these functions? I'm assuming it is a keyed +12v to a relay on the run circuit - load shedding relay? The whole ignition circuit, electric chokes, diagnostic plug have been removed in the process. This is todays raining day project.
Thanks and hope it is sunny somewhere,
Doug
Look into the LSR as you mention as well as a jumper between Fuse 6 & 7. Do you have voltage at pin 2 of the 9pin test connector?
Without starting try bridging the relay socket (usually pin socket 30 (hot) to 87 (path) on DIN relays; but I do not have a relay config to see) if you have some functions.
Jon
Thanks for the suggestion. Turns out it was a multi pin connector on the wiper switch harness - must have bumped it while renovating electrical.
