I managed to finally get the car out driving after taking out the thermostat to stop the engine over heating. While driving I am having the following issues, perhaps somebody could shed some light on them
1: After driving for about 30mins the brake pedal starts to get really stiff and harder to push, if I turn the car off for about 20mins and on again it is fine for another 30mins of driving then it starts to get stiff again. Any ideas?
2: With the thermostat out the engine keeps a nice temp while driving in the city and while stopped but once I start moving the temp drops into the blue. I can only assume that this is because the thermostat is removed. Will this cause any issues other than burning more fuel when in the blue on the temp guage?
3: While driving and pushing the car hard the floor and drive shaft area inside the cab get quite hot, the seat belt bolts even get hot to touch. Is this normal, and when driving should there be so much heat coming from the engine, when the wind blows you get wafts of hot air coming into the cab?
Cheer,
Glanceb
Cheer,
Glanceb
