Malc
Well just before I can away for work, I'm in Calgary right now, my 1986 e28 M535 went through the point of no return, the exhaust fell off! the rear subframe bushes are gone so I really can't be bothered to fix it, especially as it was originally bought to provide some spares for the dear old bucket.
Anyway suffering from jet lag and wide awake I was pondering the following and your input would be appreciated.
1].. I would like to keep the original engine, as the numbers match
2].. Could I use the cylinder head off the M535 as i believe it has bigger valves and is of a better design
3].. I have continued to toy with the idea of using the Motronics system, but I don't really like the big "flappy paddle" air flow meter.
4].. I much prefer the E9 intake mainfold setup
5].. Mix and match is attactive
6].. I could design a circuit for a modern MAP sensor to emmulate the output of the Motronic air flow meter, there's a thought. any good sources of info regarding MAP sensors and a Motronic flappy paddle sensor?
7]... Thus "fooling" the Motronic ECU into thinking it had the "right" sensors.
8].. Use later injectors but "barb" fittings with an early 5-series injector rail, thus keeping the "correct" intake set up.
Or should I really try and get some sleep?
I should be told
Malc :wink:
I should be told
Malc :wink:
