Getting set for the first start of the rebuilt engine (M30B35) and am having a problem with the oil pressure. The engine was rebuilt by a local reputable shop.
I have pulled the spark plugs, squirted some oil into the cylinders, filled the oil filter housing with oil. I have 6-7 qts in the pan. Fuel pump fuse is pulled. I crank and crank with the starter motor and get no pressure. The valve cover is off and I have been dripping additional oil onto the cam and springs. Nothing coming out of the spray bar. So I am thinking that there may be a problem somewhere. Options I have considered are:
Oil filter incorrectly installed? ( I have top mount bolt style)
Incorrect oil filter housing gasket?
Wrong head gasket installed?
Not enough engine speed during cranking to build pressure?
Oil pump sprocket not engaged properly on shaft?
Anything else I could be missing? Is there a special procedure for firing up an M30? I will drain the oil and check on the first two possibilities - but I am fairly sure I installed these correctly.
Thanks,
Thanks,
