decoupe
(deceased)
In the process of modifying my accelerator linkage, I found a crack on the driver side engine mount starting at the leading edge and spreading through the lower bolt hole and more than half way across the face.
When viewed on edge, the mount has a 1/4" deflection below the lower bolt hole. Is this part of the design - I assume so or I'm producing a lot more torque than the original engine did.
I'm somewhat surprised at the failure given the thickness of the material and OEM rubber bushing (as opposed to urethane). As the part is no longer available I'll probably weld the crack and gusset the mount with some plate to create a right angle connection at the leading edge. As this is curved when viewed "face on" this won't be easy.
Any other suggestions?
Doug
Doug
