Well it's been about 6 years but I finally have the engine running and the coupe should be back on the road in a few months! I've done the Motronic 1.3 conversion with a 3.5L from a 90 535i completely rebuilt. I now have an overheating issues. I start the engine and let it run for about ten minutes and it slowly starts creeping up into the red; I shut it off before it gets into the red. The water pump and thermostat are both brand new. The radiator is what was in the car before the swap which I never had overheating problems with. I have a 9 bladed fan and viscous clutch from a 635i I found at the junk yard but they look brand new; the car I pulled them off of had just had a the top end done and had everything new, pump clutch, fan, radiator, so I think they are ok. I have the front end jacked up and have bled the system numerous times and still have the problem. How can you tell if the viscous clutch is working properly? Little resistance to rotation when cold and more when hot? I have borrowed a pyrometer from work and will check temperatures around the engine/radiator tonight. Any help/suggestions is appreciated.
Thanks!
Thanks!
